en:sidebar:remoteapi:apiref:token:update [08/07/2015 11:05] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:token:update [11/03/2019 14:24] mani [Access flags] |
Line 27: | Line 27: | ||
| fl | access flags | | | fl | access flags | | ||
| p | custom parameters, value must be object or an array of objects\\ p:{} is minimal | | | p | custom parameters, value must be object or an array of objects\\ p:{} is minimal | | ||
- | | items | list of item ids with token granted access | | + | | items | list of item ids with token granted access, optional | |
| deleteAll | actual for **callMode:delete**; values: **1** or **true** - delete all created tokens | | | deleteAll | actual for **callMode:delete**; values: **1** or **true** - delete all created tokens | | ||
Line 51: | Line 51: | ||
| 0x1000 | modification of critical data, including messages deletion | | | 0x1000 | modification of critical data, including messages deletion | | ||
| 0x2000 | communication | | | 0x2000 | communication | | ||
- | | -1 | unlimited operation as authorizated user\\ (allows to manage user tokens) | | + | | 0xFFFFFFFF | unlimited operation as authorizated user\\ (allows to manage user tokens) | |
:!: More info you can get [[../format/token|here]]. | :!: More info you can get [[../format/token|here]]. |
