en:sidebar:remoteapi:apiref:requests:gis_render [25/11/2014 08:30] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:requests:gis_render [26/06/2019 05:28] chdi [Parameters] |
Line 5: | Line 5: | ||
<code> | <code> | ||
- | https://render-maps.wialon.com/{host}/gis_render/<x>_<y>_<z>/<uid>/<tile_name>.png?density=... | + | https://{host}/gis_render/<x>_<y>_<z>/<uid>/<tile_name>.png?density=... |
- | **Note**: {host} is usually hst-api.wialon.com. | ||
Line 17: | Line 16: | ||
| density | tile size, optional | | | density | tile size, optional | | ||
- | Tile coordinates are calculated according concept described in [[http://code.google.com/intl/en/apis/maps/documentation/javascript/v2/overlays.html#Custom_Map_Types|Google Custom Map Types]]. | + | Tile coordinates are calculated according concept described in [[https://developers.google.com/maps/documentation/javascript/coordinates#tile-coordinates|Google Custom Map Types]]. |
==== Density ==== | ==== Density ==== | ||
The param is optional. On default tile size is 256*256. | The param is optional. On default tile size is 256*256. | ||
Line 23: | Line 22: | ||
^ Value ^ Tile size ^ Ratio ^ | ^ Value ^ Tile size ^ Ratio ^ | ||
| 1 | 256*256 | 1 | | | 1 | 256*256 | 1 | | ||
- | | 2 | 378*378 | 1.5 | | + | | 2 | 384*384 | 1.5 | |
| 3 | 512*512 | 2 | | | 3 | 512*512 | 2 | | ||
| 4 | 768*768 | 3 | | | 4 | 768*768 | 3 | |
