Both sides previous revision Previous revision | |||
en:sidebar:remoteapi:apiref:requests:avl_render [15/11/2017 13:22] stan [Parameters] |
en:sidebar:remoteapi:apiref:requests:avl_render [23/12/2019 10:01] chdi [Parameters] |
Line 17: | Line 17: | ||
| sid | session id | | | sid | session id | | ||
- | adfurl<unit> is specific variable to avoid browser caching with changing <uint> value in session. | ||
- | Tile coordinates are calculated according concept described in [[http://www.maptiler.org/google-maps-coordinates-tile-bounds-projection/|Google Custom Map Types]]. | + | <code javascript>"adfurl":<uint> /* is specific variable to avoid browser caching with changing <uint> value in session. */</code> |
+ | Tile coordinates are calculated according concept described in [[http://www.maptiler.org/google-maps-coordinates-tile-bounds-projection/|Google Custom Map Types]].Zoom tiles for Webgis from 17 to z | ||
===== Tile size ===== | ===== Tile size ===== | ||
On default tile size is 256*256. In order to change tile size you may use **render/set_locale** with //density// param. | On default tile size is 256*256. In order to change tile size you may use **render/set_locale** with //density// param. | ||
Returns an image in PNG format. | Returns an image in PNG format. |
