Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:requests:avl_render [25/11/2014 08:48] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:requests:avl_render [19/01/2016 11:53] stan [Parameters] |
Line 17: | Line 17: | ||
| sid | session id | | | sid | session id | | ||
- | Tile coordinates are calculated according concept described in [[http://code.google.com/intl/en/apis/maps/documentation/javascript/v2/overlays.html#Custom_Map_Types|Google Custom Map Types]]. | + | Tile coordinates are calculated according concept described in [[http://www.maptiler.org/google-maps-coordinates-tile-bounds-projection/|Google Custom Map Types]]. |
===== Tile size ===== | ===== Tile size ===== | ||
On default tile size is 256*256. In order to change tile size you may use **render/set_locale** with //density// param. | On default tile size is 256*256. In order to change tile size you may use **render/set_locale** with //density// param. | ||
Returns an image in PNG format. | Returns an image in PNG format. |
