en:sidebar:remoteapi:apiref:requests:avl_item_image [20/11/2013 08:44] zuve |
en:sidebar:remoteapi:apiref:requests:avl_item_image [13/03/2023 10:45] yami [Unit image] |
Line 5: | Line 5: | ||
<code> | <code> | ||
- | http://{host}/avl_item_image/<item_id>/<max_border>/<name>.png | + | http://{host}/avl_item_image/<item_id>/<max_border>/<any.png>?b=<long>&v=<bool>&sid=<text> |
Line 12: | Line 12: | ||
| item_id | unit ID | | | item_id | unit ID | | ||
| max_border | max image size (from 16 to 256 pixels, recommended: 32) | | | max_border | max image size (from 16 to 256 pixels, recommended: 32) | | ||
- | | name | any value (optional), specified if it is needed to download the image instead of using the cached value | | + | | any | any value (optional), specified if it is needed to download the image instead of using the cached value | |
+ | | sid | session ID | | ||
Returns an image in PNG format. | Returns an image in PNG format. |
