en:sidebar:remoteapi:apiref:requests:avl_driver_image [20/11/2013 08:44] zuve |
en:sidebar:remoteapi:apiref:requests:avl_driver_image [29/11/2013 13:31] 127.0.0.1 external edit |
Line 5: | Line 5: | ||
<code> | <code> | ||
- | http://{host}/avl_driver_image/<rid>/<did>/<max_border>/<ck>.png | + | http://{host}/avl_driver_image/<rid>/<did>/<max_border>/<any.png> |
Line 13: | Line 13: | ||
| did | driver(trailer) ID | | | did | driver(trailer) ID | | ||
| max_border | max image size (from 16 to 256 pixels, recommended: 32) | | | max_border | max image size (from 16 to 256 pixels, recommended: 32) | | ||
- | | ck | any value (optional), specified if it is needed to download the image instead of using the cached value | | + | | any | any value (optional), specified if it is needed to download the image instead of using the cached value | |
Returns the image in PNG format. | Returns the image in PNG format. |
