en:sidebar:remoteapi:apiref:requests:address [19/09/2014 06:56] mast |
en:sidebar:remoteapi:apiref:requests:address [24/05/2016 09:43] stan |
Line 5: | Line 5: | ||
<code> | <code> | ||
- | https://geocode-maps.wialon.com/hst-api.wialon.com/gis_geocode?coords=[{"lon":<double>,"lat":<double>}]&city_radius=<uint>& | + | https://geocode-maps.wialon.com/{host}/gis_geocode?coords=[{"lon":<double>,"lat":<double>}]&city_radius=<uint>& |
- | dist_from_unit=<uint>&txt_dist=<text>&flags=<uint>&tags=<text>&uid=<long> | + | dist_from_unit=<uint>&txt_dist=<text>&flags=<uint>&uid=<long> |
- | :!: You can find an example of this request in the sample [[../../codesamples/address_coords]]. | + | **Note**: {host} is usually hst-api.wialon.com. |
+ | \\ :!: You can find an example of this request in the sample [[../../codesamples/address_coords]]. | ||
Line 18: | Line 19: | ||
| txt_dist | metrics of maximal distance from unit (optional) | | | txt_dist | metrics of maximal distance from unit (optional) | | ||
| flags | flags of output format (see below) | | | flags | flags of output format (see below) | | ||
- | | tags | maps for searching (optional) | | ||
| uid | current user ID | | | uid | current user ID | | ||
