Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:requests:address [19/09/2014 06:56] mast |
en:sidebar:remoteapi:apiref:requests:address [19/09/2014 07:36] mast |
Line 5: | Line 5: | ||
<code> | <code> | ||
- | https://geocode-maps.wialon.com/hst-api.wialon.com/gis_geocode?coords=[{"lon":<double>,"lat":<double>}]&city_radius=<uint>& | + | https://geocode-maps.wialon.com/{host}/gis_geocode?coords=[{"lon":<double>,"lat":<double>}]&city_radius=<uint>& |
dist_from_unit=<uint>&txt_dist=<text>&flags=<uint>&tags=<text>&uid=<long> | dist_from_unit=<uint>&txt_dist=<text>&flags=<uint>&tags=<text>&uid=<long> | ||
- | :!: You can find an example of this request in the sample [[../../codesamples/address_coords]]. | + | **Note**: {host} is usually hst-api.wialon.com. |
+ | \\ :!: You can find an example of this request in the sample [[../../codesamples/address_coords]]. | ||
===== Parameters ===== | ===== Parameters ===== |
