en:sidebar:remoteapi:apiref:order:update [13/12/2016 17:26] stan |
en:sidebar:remoteapi:apiref:order:update [02/10/2017 11:31] stan [Create/update] |
Line 1: | Line 1: | ||
{{indexmenu_n>1}} | {{indexmenu_n>1}} | ||
- | ====== Create/update ====== | + | ====== Update order ====== |
Basic method to work with orders is **orders/update**: | Basic method to work with orders is **orders/update**: | ||
+ | ====How to start?==== | ||
+ | * Create an order with callMode:"create" (if no unit is assigned to order then order details response will return s:0); | ||
+ | * Assign unit to the order using callMode:"assign" (order details response will return s:1); | ||
+ | * Manually move an order to hostory using callMode:"register". | ||
+ | ==== Create/update ==== | ||
- | svc=order/update¶ms={"n":<text>, | + | svc=order/update¶ms={"itemId":<long>, /* resource id */ |
- | "p": { | + | "id":<long>, /* order id (0 if create) */ |
- | "ut":<long>, | + | "n":<text>, /* order name */ |
- | "ntf":<uint>, /* notifications flags */ | + | "oldOrderId":<long>, /* old oreder id */ |
- | "r":{ | + | "oldOrderFiles":[<text>], /* old order files array */ |
- | "ndt":<uint>, /* time to notify customer before assumed delivery time, s */ | + | "p":{ /* ser-defined object content */ |
- | ... | + | "n":<text>, /* client name */ |
- | } | + | "p":<text>, /* phone */ |
- | ... | + | "p2":<text>, /* second phone */ |
+ | "e":<text>, /* email */ | ||
+ | "a":<text>, /* address */ | ||
+ | "v":<uint>, /* volume */ | ||
+ | "w":<uint>, /* weight, kg */ | ||
+ | "c":<uint>, /* cost */ | ||
+ | "ut":<uint>, /* time to order unloading, s */ | ||
+ | "t":<text>, /* type of vehicle */ | ||
+ | "d":<text>, /* description */ | ||
+ | "uic":<text>, /* number of shipping document */ | ||
+ | "cid":<text>, /* custom ID */ | ||
+ | "cm":<text>, /* comment from confirm/reject */ | ||
+ | "aff":<text>, /* [ warehouse ] list of unit ID's of warehouse ("123,456") */ | ||
+ | "z":<text>, /* [ warehouse ] list of geofences of warehouse ("resId_geofenceId,...") */ | ||
+ | "ntf":<uint>, /* notification flags: 1 - sms to first phone; 0x2 - sms to second phone; 0x10 - to email*/ | ||
+ | "pr":<uint>, /* order priority */ | ||
+ | "tags":[<uint>] /* order tags */ | ||
+ | "r": { /* route infotmation */ | ||
+ | "id":<text>, /* route id */ | ||
+ | "i":<text>, /* number [0..] */ | ||
+ | "m":<text>, /* mileage from previous point according to the plan, m */ | ||
+ | "t":<text>, /* time from previous point according to the plan, s */ | ||
+ | "ndt":<uint>, /* time to notify customer before assumed delivery time, s */ | ||
+ | "vt":<text> /* visit time according to the plan, UNIX_TIME */ | ||
- | "rp":<text>, | + | "rp":<text>, /* order route */ |
- | "f":<uint>, | + | "f":<uint>, /* order flags */ |
- | "tf":<uint>, | + | "tf":<uint>, /* lower bound of order completion time, UNIX-time */ |
- | "tt":<uint>, | + | "tt":<uint>, /* upper bound of order completion time, UNIX-time */ |
- | "trt":<uint>, | + | "trt":<uint>, /* acceptable time of advancing the schedule, s */ |
- | "r":<uint>, | + | "r":<uint>, /* order point radius, m */ |
- | "y":<double>, | + | "y":<double>, /* order point latitude */ |
- | "x":<double>, | + | "x":<double>, /* order point longitude */ |
- | "u":<long>, | + | "u":<long>, /* unit id */ |
- | "itemId":<long>, | + | "ej": {}, /* extended json (optional) */ |
- | "id":<long>, | + | "tz":<int>, /* user time stamp */ |
- | "ej": {}, /* extended json (optional) */ | + | "callMode":<text>, /* "create"/"delete" to create/delete respectively */ |
- | "tz":<int>, | + | |
- | "callMode":<text>, | + | |
"dp":"[<uint>,..]" /* array of dependent orders IDs */ | "dp":"[<uint>,..]" /* array of dependent orders IDs */ | ||
- | To delete an order: | + | ====Deleting order==== |
- | svc=order/update¶ms={"itemId":<long>, | + | svc=order/update¶ms={"itemId":<long>, /* resource id */ |
- | "id":<long>, | + | "id":<long>, /* order id (0 if create) */ |
"callMode":"delete"} | "callMode":"delete"} | ||
- | To manually move order to history: | + | ==== Manually moving order to history==== |
"callMode":"register"} | "callMode":"register"} | ||
- | To assign unit to order: | + | ====Assigning unit to order==== |
"callMode":"assign"} | "callMode":"assign"} | ||
- | To reject order: | + | ====Rejecting order==== |
"callMode":"reject"} | "callMode":"reject"} | ||
- | To confirm order: | + | ====Confirming order==== |
"callMode":"confirm"} | "callMode":"confirm"} | ||
- | =====Parameters===== | ||
- | ^ Name ^ Description ^ | ||
- | | **n** | order name | | ||
- | | **p** | user-defined data object (in any case define at least empty object in the param: **p:{}**) | | ||
- | | **x** | order point longitude | | ||
- | | **y** | order point lattitude | | ||
- | | **r** | order point radius, m | | ||
- | | **rp** | order route | | ||
- | | **f** | order flags | | ||
- | | **tf** and **tt** | bounds of order completion time, lower time and upper time accordingly, UNIX-time | | ||
- | | **trt** | acceptable time of advancing the schedule, s | | ||
- | | **u** | unit id (you may state id:0 to assign unit to order later) | | ||
- | | **ut** | time to order unloading, s | | ||
- | | **itemId** | resource id | | ||
- | | **id** | order id within resource | | ||
- | | tz | временная зона пользователя | | ||
- | | **callMode** | call mode: "create", "update", "delete", "register" (move order to history),\\ "assign" (assign unit to order), "reject", "confirm" - mark as completed | | ||
- | :!: ''x'', ''y'' и ''r'' parameters form area that assigned unit should visit to complete order. | + | ====Flags (f)==== |
- | =====Flags (f)===== | + | |
^Value^Description^ | ^Value^Description^ | ||
| 0x1 | order would be marked as completed if there were at least one message within order area with zero speed in it; | | | 0x1 | order would be marked as completed if there were at least one message within order area with zero speed in it; | | ||
Line 96: | Line 106: | ||
\\ :!: Flags **0x8**,**0x10** considered in optimization, only if orders are in "warehouses" array. | \\ :!: Flags **0x8**,**0x10** considered in optimization, only if orders are in "warehouses" array. | ||
- | =====How to start?===== | ||
- | * Create an order with callMode:"create" (if no unit is assigned to order then order details response will return s:0); | ||
- | * Assign unit to the order using callMode:"assign" (order details response will return s:1); | ||
- | * Manually move an order to hostory using callMode:"register". | ||
=====Response ===== | =====Response ===== | ||
Line 149: | Line 154: | ||
"sf":<uint>, /* order status flag (0x100 - rejected, 0x200 - confirmed, 0x400 - order is notifited) */ | "sf":<uint>, /* order status flag (0x100 - rejected, 0x200 - confirmed, 0x400 - order is notifited) */ | ||
"st":<uint>, /* last status modification time */ | "st":<uint>, /* last status modification time */ | ||
- | "tz":<uint> /* временная зона пользователя */ | + | "tz":<uint> /* user time stamp */ |
]</code> | ]</code> |
