en:sidebar:remoteapi:apiref:messages:get_messages [18/03/2015 13:29] mast |
en:sidebar:remoteapi:apiref:messages:get_messages [21/12/2022 08:08] (current) mani [Response] |
Line 33: | Line 33: | ||
Response example (no filtering): | Response example (no filtering): | ||
- | "count": 1, | + | { |
- | "messages": [{ | + | "t": 1426233861, |
- | "t": 1426233861, | + | "f": 7, |
- | "f": 7, | + | "tp": "ud", |
- | "tp": "ud", | + | "pos": { |
- | "pos": { | + | "y": 53.84541, |
- | "y": 53.84541, | + | "x": 27.4470783333, |
- | "x": 27.4470783333, | + | "z": 0, |
- | "z": 0, | + | "s": 25, |
- | "s": 25, | + | "c": 285, |
- | "c": 285, | + | "sc": 255 |
- | "sc": 255 | + | }, |
- | }, | + | "i": 0, |
- | "i": 0, | + | "o": 0, |
- | "o": 0, | + | "p": { |
- | "p": { | + | "adc1": 0, |
- | "adc1": 0, | + | "pre2": 123, |
- | "pre2": 123, | + | "param": 24, |
- | "param": 24, | + | "param5": 43 |
- | "param5": 43 | + | } |
Filter example: | Filter example: | ||
Line 65: | Line 64: | ||
Filtered response: | Filtered response: | ||
- | "pos": { | + | "x": 27.4470783333 |
- | "x": 27.4470783333 | + | }, |
- | "p": { | + | "pre2": 123, |
- | "pre2": 123, | + | "param5": 43 |
After filtering we see pos.x value, values for parameters in pos-object with leading "pre" names, values for parameters in pos-object with leading "param" and one-more-following-symbol names (for example 'param1' but 'param' is invalid for search). | After filtering we see pos.x value, values for parameters in pos-object with leading "pre" names, values for parameters in pos-object with leading "param" and one-more-following-symbol names (for example 'param1' but 'param' is invalid for search). | ||
Line 88: | Line 86: | ||
- | { | + | [ /* message array */ |
- | "count": <uint>, | + | { ... }, /* message */ |
- | "messages": [ /* message array */ | + | { ... } /* message */ |
- | { ... }, /* message */ | + | ] |
- | { ... } /* message */ | + | |
You can find message formats in the chapter [[../format/messages | Data format: Messages]]. | You can find message formats in the chapter [[../format/messages | Data format: Messages]]. |
