en:sidebar:remoteapi:apiref:item:update_name [13/02/2013 06:37] alek |
en:sidebar:remoteapi:apiref:item:update_name [29/11/2013 13:31] (current) |
Line 2: | Line 2: | ||
====== Rename ====== | ====== Rename ====== | ||
- | To rename an item, use the command **core/update_name**: | + | To rename an item, use the command **item/update_name**: |
svc=item/update_name¶ms={"itemId":<long>, | svc=item/update_name¶ms={"itemId":<long>, |
