en:sidebar:remoteapi:apiref:item:update_name [25/01/2013 14:33] zuve |
en:sidebar:remoteapi:apiref:item:update_name [22/05/2013 07:51] zuve |
Line 1: | Line 1: | ||
{{indexmenu_n>1}} | {{indexmenu_n>1}} | ||
- | ====== Renaming ====== | + | ====== Rename ====== |
- | To rename item use command **core/update_name**: | + | To rename an item, use the command **item/update_name**: |
svc=item/update_name¶ms={"itemId":<long>, | svc=item/update_name¶ms={"itemId":<long>, | ||
Line 10: | Line 10: | ||
- | | itemId | ID элемента | | + | | itemId | item ID | |
- | | name | новое название (должно содержать более 4 символов) | | + | | name | new name (at least 4 characters) | |
Line 17: | Line 17: | ||
- | "nm":<text> /* new name of item */ | + | "nm":<text> /* item new name */ |
</code> | </code> |
