en:sidebar:remoteapi:apiref:item:update_custom_property [13/02/2013 07:01] alek |
en:sidebar:remoteapi:apiref:item:update_custom_property [24/10/2013 13:12] mast |
Line 2: | Line 2: | ||
====== Custom properties ====== | ====== Custom properties ====== | ||
+ | ===== Create/update property ===== | ||
To create a new custom property for an item or update an existed one, use the command **item/update_custom_property**: | To create a new custom property for an item or update an existed one, use the command **item/update_custom_property**: | ||
Line 7: | Line 8: | ||
"name":<text>, | "name":<text>, | ||
"value":<text>} | "value":<text>} | ||
+ | </code> | ||
+ | ===== Delete property ===== | ||
+ | To delete custom property, use the same command but with empty **value** param: | ||
+ | <code javascript> | ||
+ | svc=item/update_custom_property¶ms={"itemId":<long>, | ||
+ | "name":<text>, | ||
+ | "value":""} | ||
