Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:item:add_log_record [28/01/2013 06:58] zuve |
en:sidebar:remoteapi:apiref:item:add_log_record [28/01/2013 07:01] zuve |
Line 26: | Line 26: | ||
* **update_unit_pass**; | * **update_unit_pass**; | ||
* **update_unit_phone**; | * **update_unit_phone**; | ||
- | * **update_unit_calcflags** - update sensor calculation settings; | + | * **update_unit_calcflags** (update sensor calculation settings); |
- | * **update_unit_milcounter** - update mileage counter value; | + | * **update_unit_milcounter** (update mileage counter value); |
- | * **update_unit_bytecounter** - update GPRS traffic counter value; | + | * **update_unit_bytecounter** (update GPRS traffic counter value); |
- | * **update_unit_ehcounter** - update engone hours counter value; | + | * **update_unit_ehcounter** (update engone hours counter value); |
* **update_unit_uid**; | * **update_unit_uid**; | ||
- | * **update_unit_hw** - update hardware type; | + | * **update_unit_hw** (update hardware type); |
- | * **update_unit_hw_cfg** - update hardware configuration; | + | * **update_unit_hw_cfg** (update hardware configuration); |
- | * **update_unit_fuel_cfg** - update fuel concumption configuration; | + | * **update_unit_fuel_cfg** (update fuel concumption configuration); |
- | * **update_unit_trip_cfg** - update trip detection configuration; | + | * **update_unit_trip_cfg** (update trip detection configuration); |
* **create_sensor**; | * **create_sensor**; | ||
* **update_sensor**; | * **update_sensor**; | ||
* **delete_sensor**; | * **delete_sensor**; | ||
- | * **create_alias** - create command; | + | * **create_alias** (create command); |
- | * **update_alias** - update command; | + | * **update_alias** (update command); |
- | * **delete_alias** - delete command; | + | * **delete_alias** (delete command); |
* **create_service_interval**; | * **create_service_interval**; | ||
* **update_service_interval**; | * **update_service_interval**; | ||
Line 55: | Line 55: | ||
* **bind_unit_driver**; | * **bind_unit_driver**; | ||
* **unbind_unit_driver**; | * **unbind_unit_driver**; | ||
- | * **update_unit_report_cfg** - update parameters used in reports; | + | * **update_unit_report_cfg** (update parameters used in reports); |
- | * **update_msgs_filter_cfg** - update filtration of unit position information in messages; | + | * **update_msgs_filter_cfg** (update filtration of unit position information in messages); |
* **delete_item**; | * **delete_item**; | ||
* **create_user**; | * **create_user**; | ||
Line 65: | Line 65: | ||
* **delete_user_notify**; | * **delete_user_notify**; | ||
* **create_group**; | * **create_group**; | ||
- | * **units_group** - add/remove units into group; | + | * **units_group** (add/remove units into group); |
- | * **update_driver_units** - update the list of auto attachable units for drivers; | + | * **update_driver_units** (update the list of auto attachable units for drivers); |
* **create_resource**; | * **create_resource**; | ||
* **create_zone**; | * **create_zone**; | ||
Line 88: | Line 88: | ||
* **update_drivers_group**; | * **update_drivers_group**; | ||
* **delete_drivers_group**; | * **delete_drivers_group**; | ||
- | * **create_report** - create report template; | + | * **create_report** (create report template); |
- | * **update_report** - update report template; | + | * **update_report** (update report template); |
- | * **delete_report** - delete report template; | + | * **delete_report** (delete report template); |
* **import_pois**; | * **import_pois**; | ||
* **import_zones**; | * **import_zones**; | ||
* **create_retranslator**; | * **create_retranslator**; | ||
* **update_retranslator**; | * **update_retranslator**; | ||
- | * **units_retranslator** - add units for tertranslation; | + | * **units_retranslator** (add units for tertranslation); |
* **switch_retranslator**; | * **switch_retranslator**; | ||
* **create_route**; | * **create_route**; |
