en:sidebar:remoteapi:apiref:format:route [29/11/2013 13:31] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:format:route [29/04/2017 13:54] (current) stan [Routes] |
Line 5: | Line 5: | ||
This chapter describes flags that can be applied to routes and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be gathered into one JSON. | This chapter describes flags that can be applied to routes and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be gathered into one JSON. | ||
+ | :!: All flags are only used in DEC format. | ||
Route flags: | Route flags: | ||
- | ^ Value ^ Description | | + | ^ Value HEX ^ Value DEC ^ Description ^ |
- | | [[#General properties|0x00000001]] | base flag | | + | | [[#General properties|0x00000001]] | 1 | base flag | |
- | | [[#Custom properties|0x00000002]] | custom properties | | + | | [[#Custom properties|0x00000002]] | 2 | custom properties | |
- | | [[#Billing|0x00000004]] | billing properties | | + | | [[#Billing|0x00000004]] | 4 | billing properties | |
- | | [[#GUID|0x00000040]] | GUID | | + | | [[#GUID|0x00000040]] | 64 | GUID | |
- | | [[#Administrative fields|0x00000080]] | administrative fields | | + | | [[#Administrative fields|0x00000080]] | 128 | administrative fields | |
- | | [[#Configuration|0x00000100]] | configuration | | + | | [[#Configuration|0x00000100]] | 256 | configuration | |
- | | [[#Check points|0x00000200]] | check points | | + | | [[#Check points|0x00000200]] | 512 | check points | |
- | | [[#Schedules|0x00000400]] | schedules | | + | | [[#Schedules|0x00000400]] | 1204 | schedules | |
- | | [[#Rounds|0x00000800]] | rounds | | + | | [[#Rounds|0x00000800]] | 2048 | rounds | |
- | | 0x3FFFFFFFFFFFFFFF | set all possible flags to route | | + | | 0x3FFFFFFFFFFFFFFF | 4611686018427387903 | set all possible flags to route | |
===== General properties ===== | ===== General properties ===== | ||
Line 28: | Line 30: | ||
"cls":<uint>, /* superclass ID: "avl_route" */ | "cls":<uint>, /* superclass ID: "avl_route" */ | ||
"id":<unit>, /* route ID */ | "id":<unit>, /* route ID */ | ||
+ | "mu":<uint>, /* measure units: 0 - si, 1 - us, 2 - imperial, 3 - metric with gallons */ | ||
"uacl":<unit> /* current user access level for route */ | "uacl":<unit> /* current user access level for route */ | ||
