Both sides previous revision Previous revision | Last revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:format:route [18/07/2016 11:45] stan [General properties] |
en:sidebar:remoteapi:apiref:format:route [29/04/2017 13:54] stan [Routes] |
Line 5: | Line 5: | ||
This chapter describes flags that can be applied to routes and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be gathered into one JSON. | This chapter describes flags that can be applied to routes and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be gathered into one JSON. | ||
+ | :!: All flags are only used in DEC format. | ||
Route flags: | Route flags: | ||
- | ^ Value ^ Description | | + | ^ Value HEX ^ Value DEC | Description | |
- | | [[#General properties|0x00000001]] | base flag | | + | | [[#General properties|0x00000001]] | 1 | base flag | |
- | | [[#Custom properties|0x00000002]] | custom properties | | + | | [[#Custom properties|0x00000002]] | 2 | custom properties | |
- | | [[#Billing|0x00000004]] | billing properties | | + | | [[#Billing|0x00000004]] | 4 | billing properties | |
- | | [[#GUID|0x00000040]] | GUID | | + | | [[#GUID|0x00000040]] | 64 | GUID | |
- | | [[#Administrative fields|0x00000080]] | administrative fields | | + | | [[#Administrative fields|0x00000080]] | 128 | administrative fields | |
- | | [[#Configuration|0x00000100]] | configuration | | + | | [[#Configuration|0x00000100]] | 256 | configuration | |
- | | [[#Check points|0x00000200]] | check points | | + | | [[#Check points|0x00000200]] | 512 | check points | |
- | | [[#Schedules|0x00000400]] | schedules | | + | | [[#Schedules|0x00000400]] | 1204 | schedules | |
- | | [[#Rounds|0x00000800]] | rounds | | + | | [[#Rounds|0x00000800]] | 2048 | rounds | |
- | | 0x3FFFFFFFFFFFFFFF | set all possible flags to route | | + | | 0x3FFFFFFFFFFFFFFF | 4611686018427387903 | set all possible flags to route | |
===== General properties ===== | ===== General properties ===== |
