en:sidebar:remoteapi:apiref:format:messages [02/12/2019 14:44] sden [Message with data] |
en:sidebar:remoteapi:apiref:format:messages [21/12/2022 16:59] mani [wln messages] |
Line 13: | Line 13: | ||
| [[#Command|0x0200]] | 512 | command | | | [[#Command|0x0200]] | 512 | command | | ||
| [[#Event|0x0600]] | 1536 | event | | | [[#Event|0x0600]] | 1536 | event | | ||
+ | | [[#Video usage|0x2000]] | 8192 | video usage | | ||
| **Resource messages** ||| | | **Resource messages** ||| | ||
| [[#Notification|0x0300]] | 768 | notification | | | [[#Notification|0x0300]] | 768 | notification | | ||
Line 54: | Line 55: | ||
"lc":<int>, /* lbs message checksum */ | "lc":<int>, /* lbs message checksum */ | ||
- | "rt":<uint>, /* message registration time (UTC) */ | + | "rt":<uint> /* message registration time (UTC) */ |
Line 129: | Line 130: | ||
| 0x10 | 16 | is set in addition to flag 0x2: maintenance is registered | | | 0x10 | 16 | is set in addition to flag 0x2: maintenance is registered | | ||
| 0x20 | 32 | is set in addition to flag 0x2: registered filling | | | 0x20 | 32 | is set in addition to flag 0x2: registered filling | | ||
+ | ===== Video usage ===== | ||
+ | Флаг - 0<nowiki>x</nowiki>2000(8192) | ||
+ | <code javascript> | ||
+ | "t":<uint>, /* message time (UTC) */ | ||
+ | "f":<uint>, /* flags */ | ||
+ | "tp":"xx", /* message type */ | ||
+ | "p":{ /* parameters */ | ||
+ | "cha_n":<uint>, | ||
+ | "bytes_in":<long>, | ||
+ | "action":<uint>, | ||
+ | "conn_id":<uint>, | ||
+ | "hw_id":<long> | ||
+ | </code> | ||
===== Notification ===== | ===== Notification ===== | ||
Line 199: | Line 219: | ||
- | REG;time;lon;lat;speed;course;double params;int params;text params;long params;boolean params; | + | REG;time;lon;lat;speed;course;double params;uint params;text params;long params;boolean params; |
