en:sidebar:remoteapi:apiref:format:messages [29/04/2017 15:00] stan [Notification] |
en:sidebar:remoteapi:apiref:format:messages [02/12/2019 14:44] sden [Message with data] |
Line 52: | Line 52: | ||
<text>:<double>, | <text>:<double>, | ||
+ | "lc":<int>, /* lbs message checksum */ | ||
+ | "rt":<uint>, /* message registration time (UTC) */ | ||
Line 63: | Line 65: | ||
| 0x08 | 8 | state information is available | | | 0x08 | 8 | state information is available | | ||
| 0x10 | 16 | message contains alarm bit | | | 0x10 | 16 | message contains alarm bit | | ||
- | | 0x20 | 32 | message contains information about driver code | | + | | 0x20 | 32 | message contains information about driver code which come only in parameter avl_driver | |
| 0x20000 | 131072 | message was corrected by lbs | | | 0x20000 | 131072 | message was corrected by lbs | | ||
