en:sidebar:remoteapi:apiref:format:messages [29/04/2017 14:57] stan [Message with data] |
en:sidebar:remoteapi:apiref:format:messages [21/12/2022 16:59] mani [wln messages] |
Line 13: | Line 13: | ||
| [[#Command|0x0200]] | 512 | command | | | [[#Command|0x0200]] | 512 | command | | ||
| [[#Event|0x0600]] | 1536 | event | | | [[#Event|0x0600]] | 1536 | event | | ||
+ | | [[#Video usage|0x2000]] | 8192 | video usage | | ||
| **Resource messages** ||| | | **Resource messages** ||| | ||
| [[#Notification|0x0300]] | 768 | notification | | | [[#Notification|0x0300]] | 768 | notification | | ||
Line 52: | Line 53: | ||
<text>:<double>, | <text>:<double>, | ||
+ | "lc":<int>, /* lbs message checksum */ | ||
+ | "rt":<uint> /* message registration time (UTC) */ | ||
Line 63: | Line 66: | ||
| 0x08 | 8 | state information is available | | | 0x08 | 8 | state information is available | | ||
| 0x10 | 16 | message contains alarm bit | | | 0x10 | 16 | message contains alarm bit | | ||
- | | 0x20 | 32 | message contains information about driver code | | + | | 0x20 | 32 | message contains information about driver code which come only in parameter avl_driver | |
| 0x20000 | 131072 | message was corrected by lbs | | | 0x20000 | 131072 | message was corrected by lbs | | ||
===== SMS ===== | ===== SMS ===== | ||
- | Flag - 0<nowiki>x</nowiki>0100 | + | Flag - 0<nowiki>x</nowiki>0100(256) |
Line 83: | Line 86: | ||
===== Command ===== | ===== Command ===== | ||
- | Flag - 0<nowiki>x</nowiki>0200 | + | Flag - 0<nowiki>x</nowiki>0200(512) |
Line 105: | Line 108: | ||
===== Event ===== | ===== Event ===== | ||
- | Flag - 0<nowiki>x</nowiki>0600 | + | Flag - 0<nowiki>x</nowiki>0600(1536) |
Line 120: | Line 123: | ||
Event flags: | Event flags: | ||
- | ^ Value ^ Description ^ | + | ^ Value HEX ^ Value DEC ^ Description ^ |
- | | 0x0 | simple event | | + | | 0x0 | 0 | simple event | |
- | | 0x1 | violation | | + | | 0x1 | 1 | violation | |
- | | 0x2 | maintenance event | | + | | 0x2 | 2 | maintenance event | |
- | | 0x4 | route control event | | + | | 0x4 | 4 | route control event | |
- | | 0x10 | is set in addition to flag 0x2: maintenance is registered | | + | | 0x10 | 16 | is set in addition to flag 0x2: maintenance is registered | |
- | | 0x20 | is set in addition to flag 0x2: registered filling | | + | | 0x20 | 32 | is set in addition to flag 0x2: registered filling | |
+ | ===== Video usage ===== | ||
+ | Флаг - 0<nowiki>x</nowiki>2000(8192) | ||
+ | <code javascript> | ||
+ | "t":<uint>, /* message time (UTC) */ | ||
+ | "f":<uint>, /* flags */ | ||
+ | "tp":"xx", /* message type */ | ||
+ | "p":{ /* parameters */ | ||
+ | "cha_n":<uint>, | ||
+ | "bytes_in":<long>, | ||
+ | "action":<uint>, | ||
+ | "conn_id":<uint>, | ||
+ | "hw_id":<long> | ||
+ | </code> | ||
===== Notification ===== | ===== Notification ===== | ||
- | Flag - 0<nowiki>x</nowiki>0300 | + | Flag - 0<nowiki>x</nowiki>0300(768) |
Line 143: | Line 165: | ||
===== Billing message ===== | ===== Billing message ===== | ||
- | Flag - 0<nowiki>x</nowiki>0500 | + | Flag - 0<nowiki>x</nowiki>0500(1280) |
Line 158: | Line 180: | ||
===== SMS for driver ===== | ===== SMS for driver ===== | ||
- | Flag - 0<nowiki>x</nowiki>0900 | + | Flag - 0<nowiki>x</nowiki>0900(2304) |
Line 176: | Line 198: | ||
===== Log ===== | ===== Log ===== | ||
- | Flag - 0<nowiki>x</nowiki>1000 | + | Flag - 0<nowiki>x</nowiki>1000(4096) |
Line 197: | Line 219: | ||
- | REG;time;lon;lat;speed;course;double params;int params;text params;long params;boolean params; | + | REG;time;lon;lat;speed;course;double params;uint params;text params;long params;boolean params; |
