Both sides previous revision Previous revision | Last revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:events:update_units [13/04/2016 14:42] stan |
Line 36: | Line 36: | ||
| ignition | ignition sensor (see below) | | | ignition | ignition sensor (see below) | | ||
| sensors | other sensors not mentioned above (see below) | | | sensors | other sensors not mentioned above (see below) | | ||
+ | | counters | counters | | ||
:!: To deal with "detect" elements (trips, lls, sensors, ignition) you may use sensor id or 0 (to add all sensors according to group stated). For trips it is always 0 to use (there is no trip sensor anyway). | :!: To deal with "detect" elements (trips, lls, sensors, ignition) you may use sensor id or 0 (to add all sensors according to group stated). For trips it is always 0 to use (there is no trip sensor anyway). | ||
