Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:events:get [22/03/2021 12:10] chdi |
en:sidebar:remoteapi:apiref:events:get [27/04/2021 12:40] chdi [Expression format in expr param] |
Line 59: | Line 59: | ||
=====Expression format in "expr" param===== | =====Expression format in "expr" param===== | ||
^Operator^Description^Example^ | ^Operator^Description^Example^ | ||
- | | & | AND | trips&ignition | | + | | {} | selection intervals by the value of detalization | trips{s>100}, trips with speed > 100| |
- | | %%|%% | OR | %%trips|ignition%% | | + | | - | hyphenated custom interval | 1451953325-1451953525, from-to | |
- | | ~ | NOT | trips&~ignition | | + | | %%|%% | connection custom intervals| (1615849200-1615935599%%|%%1615935601-1616022000), 2 intervals from-to| |
- | | [] | choise of sensor id | sensors[3], default first | | + | | [] | sensor's id | sensors[3], empty means 1st sensor | |
- | | () | brackets | %%trips&~ignition&(~sensors[3]|sensors[5])%% | | + | |
- | | - | hyphenated custom interval | 1451953325-1451953525&trips&ignition | | + | |
- | | {} | selection intervals by the value of detalization | trips{s<20}&ignition | | + | |
=====Response===== | =====Response===== |
