en:sidebar:remoteapi:apiref:events:get [23/04/2018 14:58] stan [0x80 flag] |
en:sidebar:remoteapi:apiref:events:get [27/04/2021 12:40] chdi [Expression format in expr param] |
Line 59: | Line 59: | ||
=====Expression format in "expr" param===== | =====Expression format in "expr" param===== | ||
^Operator^Description^Example^ | ^Operator^Description^Example^ | ||
- | | & | AND | trips&ignition | | + | | {} | selection intervals by the value of detalization | trips{s>100}, trips with speed > 100| |
- | | %%|%% | OR | %%trips|ignition%% | | + | | - | hyphenated custom interval | 1451953325-1451953525, from-to | |
- | | ~ | NOT | trips&~ignition | | + | | %%|%% | connection custom intervals| (1615849200-1615935599%%|%%1615935601-1616022000), 2 intervals from-to| |
- | | [] | choise of sensor id | sensors[3], default first | | + | | [] | sensor's id | sensors[3], empty means 1st sensor | |
- | | () | brackets | %%trips&~ignition&(~sensors[3]|sensors[5])%% | | + | |
- | | - | hyphenated custom interval | 1451953325-1451953525&trips&ignition | | + | |
- | | {} | selection intervals by the value of detalization | trips{s<20}&ignition | | + | |
=====Response===== | =====Response===== | ||
Line 162: | Line 160: | ||
"avg_speed":<uint>, /* average speed according to distance */ | "avg_speed":<uint>, /* average speed according to distance */ | ||
"distance":<uint>, /* GPS mileage in trip */ | "distance":<uint>, /* GPS mileage in trip */ | ||
- | "odometer":<uint>, /* distance for all trips */ | + | "odometer":<uint>, /* distance for all trips during all history period */ |
"course":<uint>, /* course */ | "course":<uint>, /* course */ | ||
"altitude":<uint> /* altitude */ | "altitude":<uint> /* altitude */ |
