en:sidebar:remoteapi:apiref:events:get [19/04/2016 16:06] stan [Expression format in expr param] |
en:sidebar:remoteapi:apiref:events:get [03/10/2016 13:46] stan |
Line 39: | Line 39: | ||
| timeFrom | interval start, UNIX-time | | | timeFrom | interval start, UNIX-time | | ||
| timeTo | interval end, UNIX-time | | | timeTo | interval end, UNIX-time | | ||
- | | detalization | [[./check_updates#output_flags|output flags]] | | + | | detalization | output flags (see below) | |
| indexFrom | index of the first event requested | | | indexFrom | index of the first event requested | | ||
| indexTo | index of the last event requested | | | indexTo | index of the last event requested | | ||
| filter1 | sensor ID | | | filter1 | sensor ID | | ||
- | =====Response===== | + | =====Output flags===== |
- | Reponse depends on ''type'' specified.\\ | + | ^ Flag ^ Descrition ^ |
- | Look at [[./check_updates#response|events/check_updates]] response. | + | | 0x1 | Basic JSON: event start - event end | |
+ | | 0x2 | Specified detector data | | ||
+ | | 0x4 | User parameters (those which user stated for this event) | | ||
+ | | 0x10 | Full JSON. Every detector treats it its own way | | ||
+ | | 0x20 | Formatted value | | ||
+ | | 0x40 | grouping the intersections of intervals with **tf** и **tt** | | ||
+ | | 0x80 | add summary | | ||
- | ====== Custom events intervals ====== | + | ===== Custom events intervals ===== |
To get custom events intervals use expression in **%%"expr":<text>%%** param instead **type** param. | To get custom events intervals use expression in **%%"expr":<text>%%** param instead **type** param. | ||
Line 60: | Line 66: | ||
| - | hyphenated custom interval | 1451953325-1451953525&trips&ignition | | | - | hyphenated custom interval | 1451953325-1451953525&trips&ignition | | ||
| {} | selection intervals by the value of detalization | trips{s<20}&ignition | | | {} | selection intervals by the value of detalization | trips{s<20}&ignition | | ||
- | =====Detalization flags===== | ||
- | ^ Flag ^ Description ^ | ||
- | | 0x40 | grouping the intersections of intervals with **tf** и **tt** | | ||
- | | 0x80 | add summary | | ||
=====Response===== | =====Response===== | ||
+ | Reponse depends on ''type'' specified.\\ | ||
+ | ==== 0x1 flag ==== | ||
+ | Returns basic JSON (equal to all sensor groups) | ||
+ | <code javascript> | ||
+ | "<type_name>": { | ||
+ | "<sensor_id>": { | ||
+ | "from": { | ||
+ | "t":<uint>, /* time (UNIX-time) */ | ||
+ | "y":<double>, /* latitude */ | ||
+ | "x":<double> /* longitude */ | ||
+ | "to": { | ||
+ | "m":<uint>, /* last message received time */ | ||
+ | "f":<uint> /* service flag */ | ||
+ | </code> | ||
+ | ==== 0x2 flag ==== | ||
+ | Returns specified detector data | ||
+ | "ignition": { | ||
+ | "<sensor_id>": | ||
+ | "state":<uint>, /* state: 0 - off, 1 - on */ | ||
+ | "type": 1, /* sensor type: switcher sensor */ | ||
+ | "hours":<uint>, /* engine hours for all history, sec */ | ||
+ | "switches":<uint>, /* number of swithes for all hoistory */ | ||
+ | "value":<bool> /* current value */ | ||
+ | </code> | ||
+ | Here are listed all sensor types for **sensors**: | ||
+ | "sensors": { | ||
+ | "<sensor_id1>": | ||
+ | "<sensor_id2>": | ||
+ | "type": 2, /* sensor type: instant sensor */ | ||
+ | "counter":<uint>, /* message sequence conuter in event */ | ||
+ | "summary":<uint>, /* value summary in event */ | ||
+ | "total_counter":<uint>, /* number of messages in history */ | ||
+ | "total_summary"<uint>, /* value summary in history */ | ||
+ | "value":<double> /* last value; if -348201.3876 -- value unknown */ | ||
+ | "<sensor_id3>": | ||
+ | "type": 3, /* sensor type: differential sensor */ | ||
+ | "counter":<uint>, /* value sum in event */ | ||
+ | "total_counter":<uint>, /* value sum in history */ | ||
+ | "<sensor_id4>": | ||
+ | "type": 4, /* sensor type: analog sensor */ | ||
+ | </code> | ||
+ | "lls": { | ||
+ | "value":<double>, /* last message value with calculated level */ | ||
+ | "level":<double>, /* average median value (FLS filtration value is used) */ | ||
+ | "filled":<double> /* fuel filled */ | ||
+ | </code> | ||
+ | "trips": { | ||
+ | "state":<bool>, /* state: 0 - parking, 1 - trip, 2 - stop */ | ||
+ | "max_speed":<uint>, /* max speed in trip */ | ||
+ | "curr_speed":<uint>, /* current speed */ | ||
+ | "avg_speed":<uint>, /* average speed according to distance */ | ||
+ | "distance":<uint>, /* GPS mileage in trip */ | ||
+ | "odometer":<uint>, /* distance for all trips */ | ||
+ | "course":<uint>, /* course */ | ||
+ | "altitude":<uint> /* altitude */ | ||
+ | </code> | ||
+ | "counters": { | ||
+ | "engine_hours": <uint>, /* engine hours counter */ | ||
+ | "mileage": <uint>, /* mileage counter */ | ||
+ | "bytes": <uint> /* GPRS traffic counter */ | ||
+ | </code> | ||
+ | ==== 0x4 flag ==== | ||
+ | Returns user parameters | ||
+ | Response depends on user definitions for current event. | ||
+ | "p":{ /* user-defined object content */ | ||
+ | "test":2, | ||
+ | "foo":"bar", | ||
+ | "trips":1 | ||
+ | </code> | ||
+ | ==== 0x10 flag ==== | ||
+ | Returns full JSON | ||
+ | For sensors with both ''type=2'' and ''type=3'' (except FLS): | ||
+ | "msgs": [ | ||
+ | "tm":<uint>, /* message time, UNIX-time */ | ||
+ | "v":<double> /* value */ | ||
+ | </code> | ||
+ | For FLS: | ||
+ | "lls": { | ||
+ | "msgs": [ | ||
+ | "v":<double>, /* value */ | ||
+ | "l":<double> /* average median value (FLS filtration value is used) */ | ||
+ | </code> | ||
+ | ==== 0x20 flag ==== | ||
+ | Returns formatted values | ||
+ | "sensor_id": { | ||
+ | "format": { | ||
+ | "value":<text> /* formatted value (usually "On"/"Off") */ | ||
+ | </code> | ||
+ | "value":<text> /* formatted value, depends on sensor type and format */ | ||
+ | </code> | ||
+ | "trips": { | ||
+ | "distance":<text>, /* distance according to prev message */ | ||
+ | "avg_speed":<text> /* average speed according to "distance" */ | ||
+ | </code> | ||
+ | "lls": { | ||
+ | "value":<text>, /* formatted value, depends on sensor type and format */ | ||
+ | "filled":<text> /* fuel filled */ | ||
+ | </code> | ||
+ | "engine_hours":<uint>, /* formatted value of engine hours counter */ | ||
+ | "mileage":<text>, /* formatted value of mileage counter */ | ||
+ | "bytes":<uint> /* formatted value of GPRS traffic counter */ | ||
+ | </code> | ||
====0x40 flag==== | ====0x40 flag==== |
