en:sidebar:remoteapi:apiref:events:check_updates [25/06/2015 14:57] mast |
en:sidebar:remoteapi:apiref:events:check_updates [25/06/2015 16:57] 127.0.0.1 external edit |
Line 26: | Line 26: | ||
====Sensor type==== | ====Sensor type==== | ||
- | ^ ''type'' value ^ Description ^ How events registered ^ | + | ^ ''type''\\ value ^ Description ^ How events registered ^ |
| 1 | **Switcher sensors:**\\ engine operation;\\ digital;\\ engine efficiency;\\ private mode;\\ alarm trigger;\\ counter(switch to ON/to OFF)\\ | Events are registered from ON position\\ to OFF position. | | | 1 | **Switcher sensors:**\\ engine operation;\\ digital;\\ engine efficiency;\\ private mode;\\ alarm trigger;\\ counter(switch to ON/to OFF)\\ | Events are registered from ON position\\ to OFF position. | | ||
| 2 | **Instant sensors:**\\ odometer;\\ relative engine hours;\\ instant fuel consumption;\\ counter(instant) | Events are registered from the first non-\\ zero value to the last non-zero one. | | | 2 | **Instant sensors:**\\ odometer;\\ relative engine hours;\\ instant fuel consumption;\\ counter(instant) | Events are registered from the first non-\\ zero value to the last non-zero one. | |
