Both sides previous revision Previous revision | Last revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:core:update_data_flags [08/12/2014 08:27] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:core:update_data_flags [15/05/2018 14:59] stan [Parameters] |
Line 30: | Line 30: | ||
* **id** -- by ID (if such a method is selected, you indicate item ID in the **data** parameter); | * **id** -- by ID (if such a method is selected, you indicate item ID in the **data** parameter); | ||
* **type** -- by type (if such a method is selected, you indicate item type in the **data** parameter - see [[search_items|]]); | * **type** -- by type (if such a method is selected, you indicate item type in the **data** parameter - see [[search_items|]]); | ||
- | * **col** -- by list of IDs (if such a method is selected, you write an array of item IDs in the **data** parameter). | + | * **col** -- by list of IDs (if such a method is selected, you write an array of item IDs in the **data** parameter), |
+ | * **access** -- subscribe to creating/deleting, receiving/denying access rights to items events, parameter ** data ** - 1 enable, 0 - disable. | ||
Flags application mode: | Flags application mode: |
