Differences
Both sides previous revision
Previous revision
Next revision
Previous revision
en:sidebar:remoteapi:apiref:account:update_sub_plans [13/06/2013 08:31] zuve |
en:sidebar:remoteapi:apiref:account:update_sub_plans [14/04/2014 10:09] (current) |
:!: //Attention!//\\ Current user can assign only available for him subordinate plans. To assign a billing plan to an account, the current user must have the right to manage this account (see [[../core/check_items_billing#Resources| Access flags: Resources]]). Besides, the current user must be a direct or indirect parent of the account. | :!: //Attention!//\\ Current user can assign only available for him subordinate plans. To assign a billing plan to an account, the current user must have the right to manage this account (see [[../core/check_items_billing#Resources| Access flags: Resources]]). Besides, the current user must be a direct or indirect parent of the account. |
| \\ This command is available to execute if the account already has dealer rights (you may use [[./update_dealer_rights|account/update_dealer_rights]] command). |
===== Parameters ===== | ===== Parameters ===== |
{} /* empty object if execution successful, if not - error code */ | {} /* empty object if execution successful, if not - error code */ |
</code> | </code> |
| ===== Error codes ===== |
| ^ Error code ^ Possible reason ^ |
| | 7 | no dealer rights | |
