en:sidebar:remoteapi:apiref:account:update_sub_plans [13/06/2013 08:31] zuve |
en:sidebar:remoteapi:apiref:account:update_sub_plans [14/04/2014 08:09] mast |
Line 10: | Line 10: | ||
:!: //Attention!//\\ Current user can assign only available for him subordinate plans. To assign a billing plan to an account, the current user must have the right to manage this account (see [[../core/check_items_billing#Resources| Access flags: Resources]]). Besides, the current user must be a direct or indirect parent of the account. | :!: //Attention!//\\ Current user can assign only available for him subordinate plans. To assign a billing plan to an account, the current user must have the right to manage this account (see [[../core/check_items_billing#Resources| Access flags: Resources]]). Besides, the current user must be a direct or indirect parent of the account. | ||
+ | \\ This command is available to execute if the account already has dealer rights (you may use [[./update_dealer_rights|account/update_dealer_rights]] command). | ||
Line 20: | Line 21: | ||
{} /* empty object if execution successful, if not - error code */ | {} /* empty object if execution successful, if not - error code */ | ||
+ | ===== Error codes ===== | ||
+ | ^ Error code ^ Possible reason ^ | ||
+ | | 7 | no dealer rights | |
