Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:account:update_flags [29/11/2013 12:31] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:account:update_flags [17/06/2014 15:56] mast |
Line 2: | Line 2: | ||
====== Set account settings flags ====== | ====== Set account settings flags ====== | ||
- | To set account settings flags, use the command **account/set_flags**: | + | To set account settings flags, block and/or deny balance values please use **account/set_flags** command: |
svc=account/set_flags¶ms={"itemId":<long>, | svc=account/set_flags¶ms={"itemId":<long>, | ||
- | "flags":<long>} | + | "flags":<long>, |
+ | "blockBalance":<double>, | ||
+ | "denyBalance":<double>} | ||
Line 13: | Line 15: | ||
| itemId | resource (account) ID | | | itemId | resource (account) ID | | ||
| flags | account settings flags (see [[get_account_data#Response | Detailed information about account]]) | | | flags | account settings flags (see [[get_account_data#Response | Detailed information about account]]) | | ||
+ | | blockBalance | block balance value | | ||
+ | | denyBalance | deny balance value | | ||
+ | :!: You can get additional info about kinds of balances in [[./get_account_data#account_flags|Account flags]] section. | ||
===== Response ===== | ===== Response ===== |
