en:sidebar:remoteapi:apiref:account:update_flags [30/01/2013 14:36] zuve |
en:sidebar:remoteapi:apiref:account:update_flags [17/06/2014 15:56] mast |
Line 1: | Line 1: | ||
{{indexmenu_n>9}} | {{indexmenu_n>9}} | ||
- | ====== Set configuration flags ====== | + | ====== Set account settings flags ====== |
- | To set configuration flags of account use command **account/set_flags**: | + | To set account settings flags, block and/or deny balance values please use **account/set_flags** command: |
svc=account/set_flags¶ms={"itemId":<long>, | svc=account/set_flags¶ms={"itemId":<long>, | ||
- | "flags":<long>} | + | "flags":<long>, |
+ | "blockBalance":<double>, | ||
+ | "denyBalance":<double>} | ||
- | | itemId | resource(account) ID | | + | | itemId | resource (account) ID | |
- | | flags | settings flags for account (see [[get_account_data#Response | Detailed information about account]]) | | + | | flags | account settings flags (see [[get_account_data#Response | Detailed information about account]]) | |
+ | | blockBalance | block balance value | | ||
+ | | denyBalance | deny balance value | | ||
+ | :!: You can get additional info about kinds of balances in [[./get_account_data#account_flags|Account flags]] section. | ||
===== Response ===== | ===== Response ===== |
