en:sidebar:remoteapi:apiref:account:update_flags [30/01/2013 14:36] zuve |
en:sidebar:remoteapi:apiref:account:update_flags [29/11/2013 12:31] 127.0.0.1 external edit |
Line 1: | Line 1: | ||
{{indexmenu_n>9}} | {{indexmenu_n>9}} | ||
- | ====== Set configuration flags ====== | + | ====== Set account settings flags ====== |
- | To set configuration flags of account use command **account/set_flags**: | + | To set account settings flags, use the command **account/set_flags**: |
Line 11: | Line 11: | ||
- | | itemId | resource(account) ID | | + | | itemId | resource (account) ID | |
- | | flags | settings flags for account (see [[get_account_data#Response | Detailed information about account]]) | | + | | flags | account settings flags (see [[get_account_data#Response | Detailed information about account]]) | |
===== Response ===== | ===== Response ===== |
