en:sidebar:remoteapi:apiref:account:update_billing_plan [19/06/2015 17:05] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:account:update_billing_plan [16/04/2021 06:59] (current) chdi [Response] |
Line 33: | Line 33: | ||
- | ^ Name ^ Description ^ Values ^ | ||
- | | callMode | request type | create, update, delete | | ||
- | ===Plan=== | ||
+ | | callMode | request type (create, update, delete) | | ||
| name | billing plan name (**unique field**) | | | name | billing plan name (**unique field**) | | ||
| rename | new billing plan name | | | rename | new billing plan name | | ||
Line 102: | Line 98: | ||
+ | /* smtp server settings */ | ||
+ | "smtp_host":<text>, /*server URL, example "smtps://smtp.yandex.ru"*/ | ||
+ | "smtp_login":<text>, /* login, example "savraska.nik@yandex.ru" */ | ||
+ | "smtp_port":<text>, /* port, example "4657" */ | ||
"personal": | "personal": | ||
Line 119: | Line 119: | ||
"<service_name>":{ /* put correct service name instead of <service_name> */ | "<service_name>":{ /* put correct service name instead of <service_name> */ | ||
"type": <uint>, /* type: 1 - on demand; 2 - periodic */ | "type": <uint>, /* type: 1 - on demand; 2 - periodic */ | ||
- | "maxUsage": <uint>, /* count of active resources of current service */ | + | "maxUsage": <int>, /* count of active resources of current service */ |
"cost": <text>, /* maximal resources count */ | "cost": <text>, /* maximal resources count */ | ||
"interval": <uint>, /* cost table */ | "interval": <uint>, /* cost table */ |
