Code Samples
Wialon development portal: unlock the potential of API and SDK
You are here:
Wialon Developers
Wialon Hosting
JavaScript API
Code Samples
Translations of this page:
en
ru
Contents
Wialon Hosting
Wialon Local
Wialon Pro
Wialon Kit
Code Samples
These are some samples to help you better understand how to work with Wialon:
Login
Get units
Change icon
Get messages
Get sensors
Edit sensors
Commands
Monitor notification count
Unit track
Get resources
Resources and accounts
Account parameters
Do payment
Driver management
Get POIs
Create POI
Create notification
Get geofences
Get geofence parameters
Create geofence
Export geofences
Gurtam map
Units on map
Unit trace
Create report template
Execute report
Execute custom report
Get remaining SMS count
Create driver
Bind driver to unit
Export resource properties
Import resource properties
Edit unit fields
Import fillings
Send fuel data by email
Get tiles of WebGIS map
Follow us on
info@gurtam.com
Copyright © 2002-2026 Gurtam
