en:pro:remoteapi:codesamples:update_item [06/03/2013 16:00] zuve |
en:pro:remoteapi:codesamples:update_item [17/04/2013 13:41] zuve |
Line 12: | Line 12: | ||
"name":"ips_unit", | "name":"ips_unit", | ||
"hwType":6 | "hwType":6 | ||
- | }&sid=<your_sid> | + | }&ssid=<your_sid> |
Line 66: | Line 66: | ||
"from":0, | "from":0, | ||
"to":0xffffffff | "to":0xffffffff | ||
Line 99: | Line 99: | ||
"itemId":51, | "itemId":51, | ||
"flags":2049 | "flags":2049 | ||
Response: | Response: | ||
Line 125: | Line 125: | ||
"itemId":652886, | "itemId":652886, | ||
"newValue":2049 | "newValue":2049 | ||
- | Результат выполнения: | + | Response: |
Line 140: | Line 140: | ||
Line 166: | Line 166: | ||
params={ | params={ | ||
"itemId":51 | "itemId":51 | ||
Line 181: | Line 181: | ||
"flags":1 | "flags":1 | ||
