en:pro:remoteapi:codesamples:search [06/03/2013 15:54] zuve |
en:pro:remoteapi:codesamples:search [29/11/2013 13:31] 127.0.0.1 external edit |
Line 14: | Line 14: | ||
"itemId":48, | "itemId":48, | ||
"flags":1025 | "flags":1025 | ||
- | }&sid=<your_sid> | + | }&ssid=<your_sid> |
Line 65: | Line 65: | ||
"from":0, | "from":0, | ||
"to":0xffffffff | "to":0xffffffff | ||
Asterisk in the parameter //propValueMask// means that in the result array there will be users with any values in the field //sys_name// (that is users of any names). It means all available users will be present in the result. Value "1" of the parameter //flags// means that basic information about the item must be included in the result. Detailed information about user flags is given in the chapter [[../apiref/format/user]]. Values of the parameters //from// and //to// which equals to 0 and 0xffffffff accordingly, indicate that all found users should be returned. | Asterisk in the parameter //propValueMask// means that in the result array there will be users with any values in the field //sys_name// (that is users of any names). It means all available users will be present in the result. Value "1" of the parameter //flags// means that basic information about the item must be included in the result. Detailed information about user flags is given in the chapter [[../apiref/format/user]]. Values of the parameters //from// and //to// which equals to 0 and 0xffffffff accordingly, indicate that all found users should be returned. |
