Differences
Both sides previous revision
Previous revision
Next revision
Previous revision
en:pro:remoteapi:codesamples:messages [07/03/2013 07:48] zuve |
en:pro:remoteapi:codesamples:messages [29/11/2013 13:31] (current) |
{{indexmenu_n>9}} | {{indexmenu_n>9}} |
====== !!!Messages ====== | ====== Messages ====== |
You can operate messages with the help of a special object -- the message loader. First, you load messages into the message loader using command [[../apiref/messages/load_interval|messages/load_interval]]. Then you can work with them. However, if you need to load other messages, you must clear the loader first, using the command [[../apiref/messages/unload|messages/unload]]. | You can operate messages with the help of a special object -- the message loader. First, you load messages into the message loader using command [[../apiref/messages/load_interval|messages/load_interval]]. Then you can work with them. However, if you need to load other messages, you must clear the loader first, using the command [[../apiref/messages/unload|messages/unload]]. |
"loadLocations":false, | "loadLocations":false, |
"loadCount":3 | "loadCount":3 |
}&sid=<your_sid> | }&ssid=<your_sid> |
</code> | </code> |
"indexTo":1, | "indexTo":1, |
"loadLocations":false | "loadLocations":false |
</code> | </code> |
params={ | params={ |
"index":0 | "index":0 |
</code> | </code> |
Response: | Response: |
<code javascript> | <code> |
0 | 0 |
</code> | </code> |
If you want to load messages for other interval or unit, [[../apiref/messages/unload|clear]] the message loader first: | If you want to load messages for other interval or unit, [[../apiref/messages/unload|clear]] the message loader first: |
<code> | <code> |
<your_wialon_pro_address>/ajax.html?svc=messages/unload¶ms={}&sid=<your_sid> | <your_wialon_pro_address>/ajax.html?svc=messages/unload¶ms={}&ssid=<your_sid> |
</code> | </code> |
</code> | </code> |
"tzOffset":134228528, | "tzOffset":134228528, |
"lang":"ru" | "lang":"ru" |
</code> | </code> |
"annotations":0, | "annotations":0, |
"roadLock":false | "roadLock":false |
</code> | </code> |
