en:pro:remoteapi:codesamples:messages [07/03/2013 07:48] zuve |
en:pro:remoteapi:codesamples:messages [27/05/2013 11:54] zuve |
Line 17: | Line 17: | ||
"loadLocations":false, | "loadLocations":false, | ||
"loadCount":3 | "loadCount":3 | ||
- | }&sid=<your_sid> | + | }&sssid=<your_sid> |
Line 67: | Line 67: | ||
"indexTo":1, | "indexTo":1, | ||
"loadLocations":false | "loadLocations":false | ||
- | }&sid=<your_sid> | + | }&ssid=<your_sid> |
Line 99: | Line 99: | ||
params={ | params={ | ||
"index":0 | "index":0 | ||
Response: | Response: | ||
- | <code javascript> | + | <code> |
0 | 0 | ||
Line 111: | Line 111: | ||
If you want to load messages for other interval or unit, [[../apiref/messages/unload|clear]] the message loader first: | If you want to load messages for other interval or unit, [[../apiref/messages/unload|clear]] the message loader first: | ||
<code> | <code> | ||
- | <your_wialon_pro_address>/ajax.html?svc=messages/unload¶ms={}&sid=<your_sid> | + | <your_wialon_pro_address>/ajax.html?svc=messages/unload¶ms={}&ssid=<your_sid> |
Line 126: | Line 126: | ||
Line 148: | Line 148: | ||
"tzOffset":134228528, | "tzOffset":134228528, | ||
"lang":"ru" | "lang":"ru" | ||
Line 178: | Line 178: | ||
"annotations":0, | "annotations":0, | ||
"roadLock":false | "roadLock":false | ||
