Code Samples
In this chapter, examples of using Remote API are described. As an example, https://hst-api.wialon.com is used as a Wialon Hosting request server and its demo login wialon_test. And for Wialon Kit https://kit-api.wialon.com is used and its demo login kitdemo. To check operability of an example, copy it to the address bar of your browser. Note that session ID is an obligatory parameter, it is derived from the login operation.
:!: Attention! Some data in examples might be outdated, so to test the samples, some of them may need to be corrected.
Available samples:
