en:local:remoteapi1504:codesamples:messages [13/03/2015 10:38] |
en:local:remoteapi1504:codesamples:messages [13/03/2015 10:38] (current) |
| {{indexmenu_n>9}} |
| ====== Messages ====== |
| You can operate messages with the help of a special object -- the message loader. First, you load messages into the message loader using either of two commands -- [[../apiref/messages/load_last|messages/load_last]] or [[../apiref/messages/load_interval|messages/load_interval]]. Then you can work with them. However, if you need to load other messages, you must clear the loader first, using the command [[../apiref/messages/unload|messages/unload]]. |
| //:!: Attention!// To launch this example at Wialon Kit, change **<nowiki>https://hst-api.wialon.com</nowiki>** for **<nowiki>https://kit-api.wialon.com</nowiki>** in all requests and use user name and password of your account to login to the system or name and password of demo user //**kitdemo kitdemo**//. |
| ===== Loading messages ===== |
| Let's load data messages with position for the interval from 01.04.2013 to 20.04.2013 with the help of the request [[../apiref/messages/load_interval|messages/load_interval]] and get first 3 of them. To query only data messages with position use mask 0xFF01 (0xFF00 - determines message type, 0x0001 - determines availability of position info in data messages). Also it is necessary to use flag 0x0001, which comes from sum of flags: 0x0000 - data messages, 0x0001 - messages with position. |
| <code> |
| https://hst-api.wialon.com/wialon/ajax.html?svc=messages/load_interval& |
| params={ |
| "itemId":34868, |
| "timeFrom":1364760000, |
| "timeTo":1366487999, |
| "flags":0x0001, |
| "flagsMask":0xFF01, |
| "loadCount":3 |
| }&sid=<your_sid> |
| </code> |
| Response: |
| <code javascript> |
| "count": 9172, |
| "messages": [{ |
| "t": 1364760081, |
| "f": 3, |
| "tp": "ud", |
| "pos": { |
| "y": 53.8396544, |
| "x": 27.5608672, |
| "z": 213, |
| "s": 0, |
| "c": 51, |
| "sc": 9 |
| "i": 0, |
| "p": { |
| "param22": 3, |
| "adc1": 12.606, |
| "pwr_ext": 12.598, |
| "param199": 0, |
| "param241": 25701, |
| "battery_charge": 0 |
| "t": 1364760381, |
| "f": 3, |
| "tp": "ud", |
| "pos": { |
| "y": 53.8396544, |
| "x": 27.5609312, |
| "z": 213, |
| "s": 0, |
| "c": 73, |
| "sc": 9 |
| "i": 0, |
| "p": { |
| "param22": 3, |
| "adc1": 12.545, |
| "pwr_ext": 12.547, |
| "param199": 0, |
| "t": 1364760682, |
| "f": 3, |
| "tp": "ud", |
| "pos": { |
| "y": 53.8396736, |
| "x": 27.5609664, |
| "z": 215, |
| "s": 0, |
| "c": 64, |
| "sc": 9 |
| "i": 0, |
| "p": { |
| "param22": 3, |
| "adc1": 12.6, |
| "pwr_ext": 12.569, |
| "param199": 0, |
| </code> |
| After loading messages, you can choose any number of them for further processing. For example, let's choose the ninth message from the loader. For this, use the request [[../apiref/messages/get_messages|messages/get_messages]]: |
| <code> |
| https://hst-api.wialon.com/wialon/ajax.html?svc=messages/get_messages& |
| params={ |
| "indexFrom":8, |
| "indexTo":9 |
| }&sid=<your_sid> |
| </code> |
| Response: |
| <code javascript> |
| "t": 1364762485, |
| "f": 3, |
| "tp": "ud", |
| "pos": { |
| "y": 53.8396992, |
| "x": 27.5609216, |
| "z": 223, |
| "s": 0, |
| "c": 45, |
| "sc": 7 |
| "i": 0, |
| "p": { |
| "param22": 3, |
| "adc1": 12.584, |
| "param199": 0, |
| </code> |
| ===== Deleting messages ===== |
| Now we will try to delete the first message using the request [[../apiref/messages/delete_message|messages/delete_message]]: |
| <code> |
| https://hst-api.wialon.com/wialon/ajax.html?svc=messages/delete_message& |
| params={ |
| "msgIndex":0 |
| }&sid=<your_sid> |
| </code> |
| Response: |
| <code javascript> |
| "error": 7 |
| </code> |
| User "wialon_test" has not enough rights for this action. However, if you check this example on your server you will get the following response: |
| <code javascript> |
| </code> |
| ===== Clear message loader ===== |
| If you want to load messages for other interval or unit, [[../apiref/messages/unload|clear]] the message loader first: |
| <code> |
| https://hst-api.wialon.com/wialon/ajax.html?svc=messages/unload¶ms={}&sid=<your_sid> |
| </code> |
| Response: |
| <code javascript> |
| </code> |
| If you try to query messages from empty loader, the following error code will be returned: |
| <code> |
| params={ |
| "indexFrom":0, |
| "indexTo":1 |
| }&sid=<your_sid> |
| </code> |
| Response: |
| <code javascript> |
| {"error":4} |
| </code> |
| ===== Rendering track layer ===== |
| If loaded messages contain geographic coordinates, a track can be built on their basis. To do this, you should load messages into a special graphic layer. Track layer can be used in the same way as the message loader. The only difference between them is graphics. |
| Let's create a track layer for our messages between 01.01.2013 and 20.01.2013. We can do it using the request [[../apiref/render/create_messages_layer|render/create_messages_layer]]: |
| <code> |
| https://hst-api.wialon.com/wialon/ajax.html?svc=render/create_messages_layer& |
| params={ |
| "layerName":"messages", |
| "itemId":34868, |
| "timeFrom":1357938000, |
| "timeTo":1358715599, |
| "tripDetector":1, |
| "trackColor":cc713cff, |
| "trackWidth":5, |
| "arrows":1, |
| "points":0, |
| "pointColor":0, |
| "annotations":0 |
| }&sid=<your_sid> |
| </code> |
| Response: |
| <code javascript> |
| "name": "messages", |
| "bounds": [53.8326976, 27.2796096, 53.9644416, 27.6123168], |
| "units": [{ |
| "id": 34868, |
| "msgs": { |
| "count": 5951, |
| "first": { |
| "time": 1356984476, |
| "lat": 53.9077377319, |
| "lon": 27.5011463165 |
| "last": { |
| "time": 1358538957, |
| "lat": 53.8397254944, |
| "lon": 27.5608959198 |
| "mileage": 699169.703025, |
| "max_speed": 118 |
| </code> |
| Besides, you can get the tiles of a track layer using the request [[../apiref/requests/avl_render|avl_render]]: |
| <code> |
| https://hst-api.wialon.com/avl_render/590_329_7/<your_sid>.png |
| </code> |
| Response: |
| {{/remote_ex/messages.png?nolink}} |
