en:sidebar:remoteapi:apiref:user:get_items_access [05/04/2016 14:41] stan |
en:sidebar:remoteapi:apiref:user:get_items_access [06/04/2020 10:51] chdi [Parameters] |
Line 15: | Line 15: | ||
| directAccess | return only items to which the user has direct access rights | | | directAccess | return only items to which the user has direct access rights | | ||
| itemSuperclass | item type (the list of all types see in the chapter [[../core/search_items|]]) | | | itemSuperclass | item type (the list of all types see in the chapter [[../core/search_items|]]) | | ||
- | | flags | flags (return: 0x1 - combined access level, 0x2 - direct access level) | | + | | flags | flags (return: 0x1 - combined access level, 0x2 - direct access level), optional, default value = 1 | |
Line 24: | Line 24: | ||
"dacl":<long> /* direct access level */ | "dacl":<long> /* direct access level */ | ||
+ | /* "directAccess":1 there is received only combined access level */ | ||
+ | "<text>":<long> /* "element ID":"calc" */ | ||
Access rights are described in chapter [[../core/check_items_billing]]. | Access rights are described in chapter [[../core/check_items_billing]]. | ||
