Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:reqformat:reqformat [10/11/2023 08:50] zant [Request format] |
en:sidebar:remoteapi:apiref:reqformat:reqformat [10/11/2023 08:57] mani [Request format] |
Line 2: | Line 2: | ||
====== Request format ====== | ====== Request format ====== | ||
- | All actions are executed only through POST requests. Additional parameters (“params”) should be given in the form of JSON. Response is also returned as JSON. All text parameters, either sent or returned, are supposed to use UTF-8 encoding. | + | All actions are executed only through POST requests, via **https** protocol. Additional parameters (“params”) should be given in the form of JSON. Response is also returned as JSON. All text parameters, either sent or returned, are supposed to use UTF-8 encoding. |
\\ :!: [[http://json.org|JSON]] is not supported HEX values, use DEC. | \\ :!: [[http://json.org|JSON]] is not supported HEX values, use DEC. | ||
