en:sidebar:remoteapi:apiref:reqformat:reqformat [01/06/2016 14:46] stan [Request format] |
en:sidebar:remoteapi:apiref:reqformat:reqformat [10/11/2023 08:50] zant [Request format] |
Line 3: | Line 3: | ||
All actions are executed only through POST requests. Additional parameters (“params”) should be given in the form of JSON. Response is also returned as JSON. All text parameters, either sent or returned, are supposed to use UTF-8 encoding. | All actions are executed only through POST requests. Additional parameters (“params”) should be given in the form of JSON. Response is also returned as JSON. All text parameters, either sent or returned, are supposed to use UTF-8 encoding. | ||
+ | \\ :!: [[http://json.org|JSON]] is not supported HEX values, use DEC. | ||
Request template: | Request template: | ||
<code> | <code> | ||
- | http://{host}/wialon/ajax.html?sid=<text>&svc=<svc>¶ms={<params>} | + | https://{host}/wialon/ajax.html?sid=<text>&svc=<svc>¶ms={<params>} |
Line 19: | Line 20: | ||
//:!: Attention!// In the following chapters, the values of only two parameters will be described. These parameters are **svc** and **params**. Session ID (**sid**) is a mandatory parameter needed to execute all requests (except [[../core/login|login]] and some requests from the chapter [[../requests/requests]]). | //:!: Attention!// In the following chapters, the values of only two parameters will be described. These parameters are **svc** and **params**. Session ID (**sid**) is a mandatory parameter needed to execute all requests (except [[../core/login|login]] and some requests from the chapter [[../requests/requests]]). | ||
+ | ===== Limitations ===== | ||
+ | [[en:sidebar:remoteapi:apiref:limits:limits]] | ||
