en:sidebar:remoteapi:apiref:order:optimize [01/06/2018 06:27] pash [Parameters] |
en:sidebar:remoteapi:apiref:order:optimize [06/09/2021 16:06] (current) vota [Response] |
Line 33: | Line 33: | ||
"priority":{<uint>:{<uint>:<uint>},...}, | "priority":{<uint>:{<uint>:<uint>},...}, | ||
"criterions":{<text>:<uint>,...}, | "criterions":{<text>:<uint>,...}, | ||
- | "preference":{<uint>:<uint>,...}} | + | "preference":{<uint>:<uint>,...} // DEPRECATED |
Line 60: | Line 61: | ||
| priority | order of orders: {unit index:{order index:expected index of order in a route}} (index equal to -1 will fix this order as last in a route)| | | priority | order of orders: {unit index:{order index:expected index of order in a route}} (index equal to -1 will fix this order as last in a route)| | ||
| criterions | route completion criterions: \\ max_mileage - maximum mileage, m;\\ max_duration - maximum duration, sec;\\ max_order_count - maximum orders count;\\ max_idling - maximum idle time between orders, sec;\\ split_intervals - if 1, then split based on intervals \\ (if the execution time of the order with unloading and moving, misses the next order time interval) | | | criterions | route completion criterions: \\ max_mileage - maximum mileage, m;\\ max_duration - maximum duration, sec;\\ max_order_count - maximum orders count;\\ max_idling - maximum idle time between orders, sec;\\ split_intervals - if 1, then split based on intervals \\ (if the execution time of the order with unloading and moving, misses the next order time interval) | | ||
- | | preference | order priority in route | | + | | preference | DEPRECATED: order priority in route | |
:!: JSON format is the same as in [[update]] request. | :!: JSON format is the same as in [[update]] request. | ||
Line 76: | Line 77: | ||
| 0x100 | order is terminated | | | 0x100 | order is terminated | | ||
| 0x200 | added visit reload warehouse | | | 0x200 | added visit reload warehouse | | ||
- | | 0x300 | route splited to several | | + | | 0x300 | route split to several | |
+ | | 0x400| split to independent route | | ||
+ | | 0x1000 | without optimization | | ||
+ | | 0x2000| calculate predict distance | | ||
=====Response===== | =====Response===== | ||
Line 119: | Line 122: | ||
:!: If only warehouse orders were assigned to unit(**0x4** flag) - it will not appear in the response. | :!: If only warehouse orders were assigned to unit(**0x4** flag) - it will not appear in the response. | ||
\\ :!: If route splited to several, it will be routes array in the response. | \\ :!: If route splited to several, it will be routes array in the response. | ||
+ | \\ :!: "p":<text> - order route, google polyline encoding format |
