Differences
Link to this comparison view
Next revision Both sides next revision
en:sidebar:remoteapi:apiref:order:optimize [01/06/2018 06:14]
pash [Parameters]
en:sidebar:remoteapi:apiref:order:optimize [01/06/2018 06:27]
pash [Parameters]
Line 58: Line 58:
 | speed | speed for optimization,​ km/h(60 on default) | | speed | speed for optimization,​ km/h(60 on default) |
 | units | units array | | units | units array |
-| priority | order of orders: {unit index:​{order index:​expected index of order in a route}} |+| priority | order of orders: {unit index:​{order index:​expected index of order in a route}} ​(index equal to -1 will fix this order as last in a route)|
 | criterions | route completion criterions: \\ max_mileage - maximum mileage, m;\\ max_duration - maximum duration, sec;\\ max_order_count - maximum orders count;\\ max_idling - maximum idle time between orders, sec;\\ split_intervals - if 1, then split based on intervals \\ (if the execution time of the order with unloading and moving, misses the next order time interval) | | criterions | route completion criterions: \\ max_mileage - maximum mileage, m;\\ max_duration - maximum duration, sec;\\ max_order_count - maximum orders count;\\ max_idling - maximum idle time between orders, sec;\\ split_intervals - if 1, then split based on intervals \\ (if the execution time of the order with unloading and moving, misses the next order time interval) |
 | preference | order priority in route | | preference | order priority in route |
