en:sidebar:remoteapi:apiref:order:optimize [19/01/2018 13:26] stan [Parameters] |
en:sidebar:remoteapi:apiref:order:optimize [07/05/2020 14:01] shmi [Optimize order execution] |
Line 33: | Line 33: | ||
"priority":{<uint>:{<uint>:<uint>},...}, | "priority":{<uint>:{<uint>:<uint>},...}, | ||
"criterions":{<text>:<uint>,...}, | "criterions":{<text>:<uint>,...}, | ||
- | "preference":{<uint>:<uint>,...}} | + | "preference":{<uint>:<uint>,...} // DEPRECATED |
Line 58: | Line 59: | ||
| speed | speed for optimization, km/h(60 on default) | | | speed | speed for optimization, km/h(60 on default) | | ||
| units | units array | | | units | units array | | ||
- | | priority | orders priority: {unit index:{order index:orders priority}} | | + | | priority | order of orders: {unit index:{order index:expected index of order in a route}} (index equal to -1 will fix this order as last in a route)| |
| criterions | route completion criterions: \\ max_mileage - maximum mileage, m;\\ max_duration - maximum duration, sec;\\ max_order_count - maximum orders count;\\ max_idling - maximum idle time between orders, sec;\\ split_intervals - if 1, then split based on intervals \\ (if the execution time of the order with unloading and moving, misses the next order time interval) | | | criterions | route completion criterions: \\ max_mileage - maximum mileage, m;\\ max_duration - maximum duration, sec;\\ max_order_count - maximum orders count;\\ max_idling - maximum idle time between orders, sec;\\ split_intervals - if 1, then split based on intervals \\ (if the execution time of the order with unloading and moving, misses the next order time interval) | | ||
| preference | order priority in route | | | preference | order priority in route | |
