en:sidebar:remoteapi:apiref:format:time:example [13/01/2016 12:28] stan [Reverse operation] |
en:sidebar:remoteapi:apiref:format:time:example [03/03/2021 08:55] (current) chdi [Example of time zone receiving tz] |
Line 6: | Line 6: | ||
1. Mathematical AND should be applied to the Azores [[timezone|timezone]] using **0xf000ffff** mask. | 1. Mathematical AND should be applied to the Azores [[timezone|timezone]] using **0xf000ffff** mask. | ||
+ | Each time decimal signed value should be performed to binary value using [[http://https://www.exploringbinary.com/twos-complement-converter/| decimal to two’s complement ]]method | ||
-3600 & 0xf000ffff | -3600 & 0xf000ffff | ||
Line 26: | Line 29: | ||
61936 | 61936 | ||
+ | <note important> Only if the original tz value < 0 (it is in this example), then mathematical OR should be applied to the result using the mask 0xffff0000. If tz value > 0, the following step is not needed.</note> | ||
2) Mathematical OR should be applied to the result using the mask **0xffff0000**. | 2) Mathematical OR should be applied to the result using the mask **0xffff0000**. | ||
