Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:format:time:example [13/01/2016 12:28] stan [Reverse operation] |
en:sidebar:remoteapi:apiref:format:time:example [16/04/2020 08:12] chdi [Reverse operation] |
Line 26: | Line 26: | ||
61936 | 61936 | ||
+ | <note important> Only if the original tz value < 0 (it is in this example), then mathematical OR should be applied to the result using the mask 0xffff0000. If tz value > 0, the following step is not needed.</note> | ||
2) Mathematical OR should be applied to the result using the mask **0xffff0000**. | 2) Mathematical OR should be applied to the result using the mask **0xffff0000**. | ||
<code=javascript> | <code=javascript> |
