en:sidebar:remoteapi:apiref:format:time:example [13/01/2016 10:03] stan [Reverse operation] |
en:sidebar:remoteapi:apiref:format:time:example [13/01/2016 12:28] stan [Reverse operation] |
Line 19: | Line 19: | ||
=====Reverse operation===== | =====Reverse operation===== | ||
+ | tz=-134155792 | ||
- | Time zone is presented as signed short. | + | 1) Mathematical AND should be applied to the ‘tz’ parameter using **0xffff** mask. |
- | tz=-134155792 in hex 0xf800f1f0 | + | |
- | 1) Value using **0x0fff0000** mask is [[dst|dst]]. | + | |
- | 0x08000000 - none. | + | |
- | 2) Value using **0xffff** mask is Time zone. | + | |
- | 0xf1f0 | + | -134155792 & 0xffff |
+ | 61936 | ||
+ | </code> | ||
+ | 2) Mathematical OR should be applied to the result using the mask **0xffff0000**. | ||
+ | <code=javascript> | ||
+ | 61936 | 0xffff0000 | ||
-3600 | -3600 | ||
+ | [[timezone|timezone]] (-01:00) Azores. | ||
+ | tz=-134155792 in hex 0xf800f1f0 | ||
- | [[timezone|Time zone]] (-01:00) Азорские о-ва. | + | Value using **0x0fff0000** mask is [[dst|dst]]. |
+ | 0x08000000 - none. |
