Differences
Link to this comparison view
Next revision
Previous revision
en:sidebar:remoteapi:apiref:format:resource [13/04/2020 08:17]
chdi [Tags (passengers)]
en:sidebar:remoteapi:apiref:format:resource [14/04/2025 06:29] (current)
zant [Drivers]
Line 165: Line 165:
  "​pu":<​long>,​ /​* previous binded unit */  "​pu":<​long>,​ /​* previous binded unit */
  "​bt":<​uint>,​ /​* time of last binging/​unbinding */  "​bt":<​uint>,​ /​* time of last binging/​unbinding */
- "​pos":​{ /​* position */+ "​pos":​{ /​* ​last position, null - if driver is bound to unit */
  "​y":<​double>,​ /​* latitude */  "​y":<​double>,​ /​* latitude */
  "​x":<​double>​ /​* longitude */  "​x":<​double>​ /​* longitude */
  infr: { /​*parameters for analysis infringements of work and rest of drivers AETR */  infr: { /​*parameters for analysis infringements of work and rest of drivers AETR */
- "​a":​ <​uint>,​ /​* current activity */ + "​a":​ <​uint>,​ /​* current activity ​type (0 — rest, 1 — availability,​ 2 — work, 3 — driving) ​*/
- "​t":​ <​uint>,​ /​* the start time of this activity */+ "​t":​ <​uint>,​ /​* the start time of this activity ​in Unix time format ​*/
  "​ud":​ <​uint>,​ /​* duration of uninterrupted driving before the current activity */  "​ud":​ <​uint>,​ /​* duration of uninterrupted driving before the current activity */
  "​ur":​ <​uint>,​ /​* duration of uninterrupted rest before the current activity */  "​ur":​ <​uint>,​ /​* duration of uninterrupted rest before the current activity */
- "​uil":​ <​uint>,​ /​* allowed duration of uninterrupted driving */ + "​uil":​ <​uint>,​ /​* allowed duration of uninterrupted driving ​(270 min) */
- "​uim":​ <​uint>,​ /​* duration of uninterrupted driving to which the violation is infringement minor */ + "​uim":​ <​uint>,​ /​* duration of uninterrupted driving to which the infringement ​is considered ​minor (300 min) */
- "​uis":​ <​uint>,​ /​* duration of uninterrupted driving to which the violation is infringement serious (above - very serious*/ + "​uis":​ <​uint>,​ /​* duration of uninterrupted driving to which the infringement ​is considered ​serious (360 min); above - very serious */
- "​uir":​ <​uint>,​ /​* duration of required rest */ + "​uir":​ <​uint>,​ /​* duration of required rest (45 minutes for each 4.5 hours) ​*/
- "​ddt":​ <​uint>,​ /​* daily driving time before the current activity */ + "​ddt":​ <​uint>,​ /​* daily driving time before the current activity ​(total driving) */
- "​ddc":​ <​uint>,​ /​* allowed number of prolonged daily driving in this week */ + "​dbt":​ <​uint>,​ /​* start time of daytime activity in Unix time format ​*/
- "​ddil":​ <​uint>,​ /​* allowed duration of daily driving */ + "​ddc":​ <​uint>,​ /​* allowed number of prolonged daily driving in this week (decrements from 2 to 0; connected to ddil, ddim, ddis) */
- "​ddim":​ <​uint>,​ /​* allowed duration of daily driving ​(minor ​infringement ) */ + "​ddil":​ <​uint>,​ /​* allowed duration of daily driving ​(if ddc:0 value is 600, else 540) */
- "​ddis":​ <​uint>,​ /​* allowed duration of daily driving ​(serious ​infringement(above very serious)) */+ "​ddim":​ <​uint>,​ /​* allowed duration of daily driving ​up to which the infringement ​is considered minor (if ddc:0 value is 660, else 600) */
 + "​ddis":​ <​uint>,​ /​* allowed duration of daily driving ​up to which the infringement ​is considered serious ​(if ddc:0 value is 720, else 660); above very serious */
  "​wdt":​ <​uint>,​ /​* duration of weekly driving before the current activity */  "​wdt":​ <​uint>,​ /​* duration of weekly driving before the current activity */
- "​wdil":​ <​uint>,​ /​* allowed duration of weekly driving */ + "​wdil":​ <​uint>,​ /​* allowed duration of weekly driving ​(3360 min) */
- "​wdim":​ <​uint>,​ /​* allowed duration of weekly driving ​(minor ​infringement) */ + "​wdim":​ <​uint>,​ /​* allowed duration of weekly driving ​up to which the infringement ​is considered minor (3600 min) */
- "​wdis":​ <​uint>,​ /​* allowed duration of weekly driving ​(serious ​infringement(above very serious)) */+ "​wdis":​ <​uint>,​ /​* allowed duration of weekly driving ​up to which infringement ​is considered serious ​(4200 min); above very serious */
  "​twdt":​ <​uint>,​ /​* duration for two weeks of driving before the current activity */  "​twdt":​ <​uint>,​ /​* duration for two weeks of driving before the current activity */
- "​twdil":​ <​uint>,/​* allowed duration for two weeks of driving */ + "​twdil":​ <​uint>,/​* allowed duration for two weeks of driving ​(5400 min) */
- "​twdim":​ <​uint>,/​* allowed duration for two weeks of driving ​(minor ​infringement) */ + "​twdim":​ <​uint>,/​* allowed duration for two weeks of driving ​up to which the infringement ​is considered minor (6000 min) */
- "​twdis":​ <​uint>,/​* allowed duration for two weeks of driving ​(serious ​infringement(above very serious)) */+ "​twdis":​ <​uint>,/​* allowed duration for two weeks of driving ​up to which the infringement ​is considered serious ​(6750 min); above very serious */
  "​drt":​ <​uint>,​ /​* duration of the previous daily rest */  "​drt":​ <​uint>,​ /​* duration of the previous daily rest */
- "​drd":​ <​uint>,​ /​* duration of the required daily rest */ + "​drd":​ <​uint>,​ /​* duration of the required daily rest (660 min by default, 540 min for reduced daily rest) */
- "​dril":​ <​uint>,​ /​* time before ​which daily rest should ​occure ​*/ + "​dril":​ <​uint>,​ /​* time in Unix time format up to which daily rest should ​begin */
- "​drim":​ <​uint>,​ /​* time before ​which an infringement ​is considered ​to be minor */ + "​drim":​ <​uint>,​ /​* time in Unix time format up to which violation of the rest period ​is considered minor (60 min more) */
- "​dris":​ <​uint>,​ /​* time before ​which an infringement ​is considered ​to be serious(above very serious*/+ "​dris":​ <​uint>,​ /​* time in Unix time format up to which violation of the rest period ​is considered serious (120 min more); ​above very serious */
  "​wrt":​ <​uint>,​ /​* duration of the previous weekly rest */  "​wrt":​ <​uint>,​ /​* duration of the previous weekly rest */
- "​wrd":​ <​uint>,​ /​* duration of the required weekly rest */ + "​wrd":​ <​uint>,​ /​* duration of the required weekly rest (2700 min by default, 1440 min for reduced weekly rest) */
- "​wril":​ <​uint>,​ /​* time before ​which weekly rest should ​occure ​*/ + "​wril":​ <​uint>,​ /​* time in Unix time format up to which weekly rest should ​begin */
- "​wrim":​ <​uint>,​ /​* time before ​which an infringement ​is considered ​to be minor */ + "​wrim":​ <​uint>,​ /​* time in Unix time format up to which violation of the rest period ​is considered minor (120 min more) */
- "​wris":​ <​uint>​ /​* time before ​which an infringement ​is considered ​to be serious(above very serious*/+ "​wris":​ <​uint>​ /​* time in Unix time format up to which violation of the rest period ​is considered serious (240 min more); ​above very serious */
Line 470: Line 471:
  "​n":<​text>,​ /​* name */  "​n":<​text>,​ /​* name */
  "​d":<​text>,​ /​* description */  "​d":<​text>,​ /​* description */
- "drs":​[<​uint>​] /​* array of geofences IDs */+ "zns":​[<​uint>​] /​* array of geofences IDs */
