en:sidebar:remoteapi:apiref:errors:errors [11/12/2017 15:31] stan [Errors] |
en:sidebar:remoteapi:apiref:errors:errors [24/04/2020 12:29] chdi [Errors] |
Line 20: | Line 20: | ||
| 10 | Reached limit of concurrent requests | | | 10 | Reached limit of concurrent requests | | ||
| 11 | Password reset error | | | 11 | Password reset error | | ||
+ | | 14 | Billing error | | ||
| 1001 | No messages for selected interval | | | 1001 | No messages for selected interval | | ||
| 1002 | Item with such unique property already exists \\ or\\ Item cannot be created according to billing restrictions| | | 1002 | Item with such unique property already exists \\ or\\ Item cannot be created according to billing restrictions| | ||
- | | 1003 | Only one request is allowed at the moment | | + | | 1003 | reason 1 - Only one request is allowed at the moment | |
+ | |1003|reason 2 - "reason":"LIMIT api_concurrent"| | ||
+ | |1003| reason 3 - "reason":"LAYERS_MAX_COUNT" | | ||
+ | |1003| reason 4 - "reason":"NO_SESSION" | | ||
+ | |1003| reason 5 - "reason":"LOCKER_ERROR"| | ||
| 1004 | Limit of messages has been exceeded | | | 1004 | Limit of messages has been exceeded | | ||
| 1005 | Execution time has exceeded the limit | | | 1005 | Execution time has exceeded the limit | | ||
+ | | 1006 | Exceeding the limit of attempts to enter a two-factor authorization code | | ||
| 1011 | Your IP has changed or session has expired | | | 1011 | Your IP has changed or session has expired | | ||
| 2014 | Selected user is a creator for some system objects, thus this user cannot be bound to a new account | | | 2014 | Selected user is a creator for some system objects, thus this user cannot be bound to a new account | | ||
| 2015 | Sensor deleting is forbidden because of using in another sensor or advanced properties of the unit | | | 2015 | Sensor deleting is forbidden because of using in another sensor or advanced properties of the unit | | ||
